Back a surface edited
I was editing surfaces and I didn't keep the original of one of them. Is there a way to came back the original surface of archicad
1 REPLY 1
Lingwisyer
Guru
Modifications to things like Surfaces only affect the host file, so you should be able to find the defaults in any other file you've saved. You can use the Attribute Manager to transfer the settings by Index to their defaults.
If you're wanting to make global changes, you'll want to be editing the template file (.tpl) that you use when you start up a new model.
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
