Basic Teamwork / Plotmaker Question
When creating a plotmaker file using a shared project I assume you have to import from the plp (not the pln) to create the drawings in layouts?
Do you use pln at all in a teamwork situation? Or is the entire project done in the plp? Seems like that is the only way to work on plotmaker concurrently with a teamwork project.
Is that correct?
Thanks
yes....your correct, you use the plp file...when you select it will bring up the Saved views you have created....and yes...the plp file is a single file that your entire team will work on.....
