a month ago
I want to connect two beams of different heights, both were made with custom profile.
On the top of the picture i show how i want to connect them, on the bottom of the picture is how they look in profile.
What is the best approach in connecting them?
Thanks!
Solved! Go to Solution.
a month ago - last edited a month ago
I tried to model it by a segmented beam but couldn't as complex profile is not supported in tapered mode.
So, it can be modeled as 3 different beams, each one has its own profile and with the help of Offset Modifiers in the middle one as follow, hope that helps.
a month ago
So sorry, forgot to tell you to change the beam size from uniform to tapered, you'll find start & end offsets.
a month ago
Have you tried creating a single segmented beam with 3 segments.
The 2 segments at each end can be your different size complex profiles and the one in the middle can be a transition between the two sizes.
This may help ... https://help.graphisoft.com/AC/29/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC29_Help%2F040_Eleme...
a month ago
- last edited
a month ago
Thanks for the video, but it didn't work.
If i try to do it like in the video, i can't change the joints.
If i do as you said, add a third segment and change the heights, it vanishes.
So i am unsure what am i doing wrong, but they are both custom profiles.
a month ago
- last edited
a month ago
Yes, thank you, this is what i want to make, specifically this one:
I tried to follow your steps, but i missed something, because this is what i get:
basically i can only stretch the whole thing.
if you know what could have gone wrong, i would appreciate it
a month ago
a month ago
Great, it works now! Thank you!
