2020-02-24
07:07 PM
2023-05-26
12:25 PM
Rubia Torres
2020-02-28 06:47 AM
2020-02-28 08:18 AM
2020-02-28 08:30 AM
GOBA wrote:I guess you mean Graphic Overrides? It's the same as a Symbolic Beam. Now that Beams have a Cover Fill, the GO can override these Cover Fills - just make sure in the Rule, that you are overriding Cover Fill types. And that this Projected Beam, uses a Cover Fill.
Thanks James! It’s true!
But, if I do that, will I be able to use overrides? I don’t find how to use them with this projection mode.
2020-02-29 10:57 AM
