2020-02-24
		07:07 PM
 - last edited on
		2023-05-26
		12:25 PM
 by
			Rubia Torres
2020-02-24 08:08 PM
2020-02-25 02:23 AM
2020-02-25 06:27 AM
2020-02-25 08:39 AM
Barry wrote:Yes.
I think you will find that because the beam and the rafters intersect with each other in 3D, the contour lines will merge in plan.
Obviously you do not want to separate them as this would make your model incorrect.
Barry wrote:I have tried, and it works. Thanks! But I wouldn’t like to have to use more layers than necessary, for this reason…
But there is a way to trick it into believing that are not intersecting.
I am assuming the beam and rafters are in the same layer or maybe different layers that have the same Intersection Priority Number.
Place them in different layers and change the IP number for one of these layers so it is different from the other.
Remember that this IP number is also stored in the layer combinations, so you will have to make sure they are set up correctly as well.
2020-02-25 08:41 AM
DGSketcher wrote:Hi DGSketcher! I didn’t know 3D documents. I am going to review the documentation. Thanks!
The new beams and cover fills is helping with plan views, but I still find the presentation order a bit tricky. For my roof framing drawings I tend to use the 3D document from plan option as this gives a true view without having to juggle elements & layers. It does have some dimensioning issues but these can usually be easily worked round.
Just a suggestion depending on what you want to achieve. Read about 3D document from plan here... https://helpcenter.graphisoft.com/user-guide/65370/
2020-02-25 09:04 AM
GOBA wrote:
What I don’t understand, is why it’s not working the “junction order” of the beam’s menu. It seems it works similarly (assigning a number), but for particular elements. Could it be a bug? Is there a place in this forum dedicated to bugs, or should I write to my seller, to check it?
2020-02-25 09:15 AM
2020-02-25 10:00 AM
2020-02-25 01:30 PM
