Beam selection only shows a centerline
I'm trying to build an arbor by creating beams across my columns. In the Beam Selection Settings dialog box / Floor Plan, I've selected a Solid Line for the outline, and a Dot & Dashed line for the centerline; Show Centerline is checked. But on the Floor Plan all that displays is the centerline -- no outlines of the beam. What to do?
Link
Check your Display Options!
Link.
Open Display Options and look at your selection for Beams. Probably says "Reference Line". Change it to "Entire Beam".
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
That did the trick . . . thanks for taking the time to help me.
Ron
