Bermuda Shutters
JKL
Any way to make shutters angle outwards in a Bermuda style shutter(like the image attached)? Archicad24 on Mac.
Thanks!
Designer
Mac
Archicad 27
amgam
Here's a quick mash-up with the setting, and once again - pardon my French. Will this do?
You can add the divisions too and schedule these elements easily.
Capture d’écran 2021-10-27 Ć  09.24.24.pngCapture d’écran 2021-10-27 Ć  09.24.32.pngCapture d’écran 2021-10-27 Ć  09.24.36.png
ArchiCAD 25 FRA 3011 + TwinMotion 2021.1.4
iMac Retina 27 2020 3,8 GHz Intel Core i7 8 cœurs
64 Go 2667 MHz DDR4
AMD Radeon Pro 5700 XT 16 Go
amgam
64 Go 2667 MHz DDR4
JKL
This looks like a winner! I'll try it out-Thanks so much!
Designer
Mac
Archicad 27
Let us know how it went and if you need more help. I'm especially curious if you manage to schedule these as elements.
64 Go 2667 MHz DDR4
