2021-07-01
		06:27 PM
		2023-05-09
		03:42 PM
			Rubia Torres
Solved! Go to Solution.
2021-07-02 03:33 PM
2021-07-01 07:57 PM
2021-07-01 11:43 PM
2021-07-02 10:33 AM
Braza wrote:Thanks for the reply. Interesting video for facades, it's a similar use as I was doing in Revit so this won't be too foreign for me. When it comes to paint, wallpaper or other types of interior wall coverings, I just use composite walls, is it the best way or should I model another element ?
I am more for using Composites (For simple top to base coverings) and Complex Profiles for the rest. I have also saw some clever uses of curtain wall for this purpose. Like this:
2021-07-02 11:23 AM
Podolsky wrote:Oh ok, I didn't know those were that old, I understand. So it's better to just use the default tools then ? For flooring, I should have two slabs (one for the structure, another for the finish), for wall coverings, I'll just use composite walls and for ceilings, also a slab I guess ?
If talk about coverings - accessories that was original tool developed for that. I don't know why it's been dragged out from official ArchiCAD package and became addition (Goodies), that Graphisoft does not want to take any technical support and take responsibilities. Initially it was part of ArchiCAD and introduced in version 7.
The problem with accessories - that all depends on quality of GDL code on those wall, ceiling and floor accessories, that usually poor. It's possible to program cool covering stuff for accessories, but not all library parts you can find online are good quality. You can make your research and test several third part coverings solutions - like Central Innovation (aka Cadimage) from Australia, I think. Or they are kiwi...
There is also very good quality libraries called 'Swift' - maybe they are offering some special tools for coverings. Some objects from BIM objects are using this accessories possibilities not bad. But in total - accessories are very old tool that never was updated (20 years already) and Revit is beating ArchiCAD about it.
I personally keeping in mind the idea to sit and program my own coverings library. And also I wish it would be more advanced, as accessories are quite primitive in terms what data are they passing to GDL object.
2021-07-02 03:33 PM
