rob2218
Black background vs. White background
I suppose you could say, "well...it's just a matter of getting used to it" but....the bottom line truth of the matter is that colors (unless your are color blind like me) on a black background can be seen much easier than colors on a white background.
For example, if you by mistake leave a small piece of a line, say 2" long and the line was drawn in pen yellow, guaranteed that the yellow is easier seen in "black" than in "white" background.
Again I understand, we all get used to drawing a certain way but there is a logic behind using a "black" background and it's not just because...."oh I like the way it looks better"....NO..it's because IT WORKS BETTER.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
32 Replies 32
I got your point Rob... But what if the line would be dark grey?
owen
of course using Pen Sets it is possible to cater for both - even within the same file. You can just swap back and forth depending on personal preference (of course changing the Grid & Background colors is still manual)
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Being colourblind also, rather than black or white, I find a neutral colour like beige works well for me. It's comfortable on the eyes for long viewing periods, all colours stand out clearly against it (except beige of course!), and objects with a white background are clearly visible.
Random example image below!
Srinivas
how about this piece of info from Krippahl
http://archicad-talk.graphisoft.com/viewtopic.php?p=151635
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
vistasp
Mentor
I used to use a light greenish grey background during my AutoCAD days and it gave a lot of relief to my eyes. Maybe I should try that again but for AC. Will have to look at the pen-set carefully of course.
Off-topic: Peter, your random image shows the FPCP in the section. Is this manually drawn or is there some setting I've missed?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Stephen Dolbee
Back in the hand-drafting days I always used white paper. White background just seems natural.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
i loved black background in autocad days cos it was all colours.
now im on AC i use a white back ground and everything (all my pens) is set to black (no colors).. for that reason i use white back ground.. my plans are printed in black and white so i see no need to draft plans in anything but
I manually drew it in. No secret setting I'm afraid!
How do you guys deal with white cover fills? If you turn on Automatic Pen Color Visibility Adjustment to make these display in grey against a white background, does it not get confusing if you also have other elements deliberately shaded in grey?
owen
I generally have my background set to something like 95% rather than pure white so these can be seen. The only pen this can cause problems for is one of our greyscale pens at 90%, but this very rarely gets used anyway.
cheers,
Owen Sharp
