Black lines to show white on black background
Could anyone enlighten me how to change black lines to show white on a black background please?
Sujey
10 Replies 10
Dwight
Use white lines: Pen 91 in most systems.
But sometimes your pen sets for a layout will differ.
Dwight Atkinson
Changing the line colour to 91 isn't a problem. The main problem is when I xref a file with black lines in it that don't show at all in the 2D window. When I select the xref, the outline appears, but is invisible.
Dwight
I the XREF attachment translation settings, you can convert the imported black lines to a visible color.
Dwight Atkinson
I take it this also applies to opening DWG files direct in AC?
David Maudlin
In addition, you might get this dialog box when opening the DWG file.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I'm on it, Thanks!
As for the dialog box, it doesn't come up anymore since user selected not to show dialog box again....any guesses on how to get it back?
Does this Work Environment setting help?
Yes! Thank you!
Link
Sujey wrote:
I'm on it, Thanks!
Options> Work Environment> Enable All Informational Messages...
Link.
