Bottom Top Slab
Hello Guys,
Is there a way that the level detect or read the bottom of a slab not the top of it in plan??
I would like to use the slab as false ceiling and read the bottom of in the reflected ceiling plan... is there a way?
Thanks guys
5 REPLIES 5
Laura Yanoviak
We use a variation of James Murray's Slab Elevation Label:
archicad-talk.graphisoft.com/viewtopic.php?t=527&postdays=0&postorder=asc&&start=22
Although (per the post) the Label Tool does have it's limitations -- LJY.
it doesn't work!!!
TomWaltz
What doesn't work? What did you do and how did it fail?
Tom Waltz
Rakela Raul
it doesn't work!!!
sorry but it does work
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
gobel wrote:
it doesn't work!!!
You have to associate the label to the slab.
