Bottom part of stair goes below floor
DangCad1
I have created a stair (AC19), but since the bottom part goes below the first step (instead of being flat), it is visible below the floor in elevation/section. How do I change this? I assume there's a setting somewhere, but I haven't found it. See screenshots below.
Screen Shot 2022-12-09 at 15.30.57.pngScreen Shot 2022-12-09 at 15.30.48.png
AC 19 / iMac 2013 3,2 Ghz 12 GB RAM / OS X El Capitan
2 ACCEPTED SOLUTIONS
There should be a setting within the stair to change the option to start the rise at floor level or the treat at floor level. You can also change the thickness of the bottom rise to match the depth of the floor slab.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.2.2 | Archicad 28 Apple Silicon
macOS Sequoia (15)
David Maudlin
DangCad1:
Look at Stair Settings > Stair > Structure > Flight Monolithic > Support Connections to see the options for changing the bottom and top of the stair.
You should add a Signature to your Profile (click the Profile button near the top of this page) with your Archicad version and operating system (see mine for an example) for more accurate help in this forum.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
5 REPLIES 5
Lee Hankins
macOS Sequoia (15)
David Maudlin
DangCad1:
Lingwisyer
Guru
In your case, you probably want to ZERO the Lower Slab Thickness
By the looks of it, you will also want to change your Top Tread Level  to Below Floor Level so that you can get your structure to finish to the bottom of your slab.
Ling.
David Maudlin
DangCad1:
Thanks for adding your Signature.
DangCad1
Thank you for the help everyone! I managed to solve it by updating the structure settings as suggested by David.
