Bring Object in front of fill
Just wondering if someone was able to help me in regards to bringing an object in front of a fill, i have set the background colour to white and brought display order to front, fill still seems to stay over top of object.
Attached pic. gives an idea of what i am talking about.
Any help would be appreciated.Thanks
4 Replies 4
Select the object then Edit> Display order> Bring to front.
if that doesn't work it may be a graphic override setting.
Yes i have tried this, doesn't seem to come to front.
Is there a quick way to explain the graphic override setting?
Thanks for your help.
Just to make sure it is the GO, go to view settings & set the GO to no overrides
Maybe the Object does not have a background fill and so nothing indicates that it is indeed in front of the Fill. The Bring to Front/Send to Back commands should work. You can also try to Send the Fill to the Back instead of Bringing the Object to the Front.
