Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
complex profile - import dwg to trace
is it possible to import a dwg to trace for a new complex profile
thanks
2 REPLIES 2
Eduardo Rolon
You can import a DWG to a worksheet and Draw the fills there and copy/paste to the Profile Window. Checking now you cannot import directly to the CP window nor use Trace Reference there.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Bruce
You cannot magic wand a dwg placed using the Drawing tool (this is usually the best way to place a dwg as it doesn't bring in all the attributes). If you care about keeping your attributes 'clean,' start a new file into which you either xref or merge the dwg, then you can magic wand a fill using attributes that already exist in your other file. Then you then copy and paste this fill into you cp window.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
