FLOOR LINKED TO WALL
Hi
Is it possible to link a floor to wall, so if I move the wall the floor slab will resize
to the new wall
Hope this makes sense
Thanks
DGSketcher
Legend
Not directly, but if the wall(s) and slab share common reference lines then you can select them and edit both at the same time. You may need to suspend groups to get it to work properly.
Bruce
You can also use the marquee with the stretch command to get this result
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
