David Bearss
Building model vanished?
Had a few moments and was fooling around with calculate menu and list schemes. Looking at the manual and browsing around in dialog boxes. I got a spontaneous invitation to lunch and upon return the building model seems to have been wiped away. The project file size has shrunk from 33 to 3 megs. Opening the bpn file results are same when I open the bpn file which is still 33 meg. It is as if I opened a new project file with no data in it with even my stories gone. Could I really have wiped out my building model by messing with list schemes? Interesting thing is the only element I can view in the drawing window is and empty list window. see attached. I can upen a three day old backup just fine. any advice??
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
5 Replies 5
Don't go out for lunch?
David Bearss
Believe me that thought crossed my mind.
David Bearss
Alienware 17 R5
The lack of response here suggests that everyone else is having same blank stares and head scratching that I do over this one. It looks like it's time to cut your losses and go back to the working backup. The up side (if there is any) is that I find it usually takes only about 20-25% of the time to redo the work than to do it the first time (the thinking part is already done).
David Bearss
Coming to the same conclusion and luckily since I was "experimenting" and not really accomplishing any real work, I will not lose that much work. The upside is I have revised my backup program to improve my file security.
David Bearss
Alienware 17 R5
It sounds like you may have just saved yourself from potential future nightmares. Seems like it's turned out all for the best.
