Building this breeze brick wall?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-10-14
02:56 AM
2023-05-24
08:09 AM
Rubia Torres
I am looking at building this breeze brick wall. Is there any tool to do it or I have to manually model it with morph ?
Please see attached.
Thanks all
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-10-14 03:37 AM
Or you could use many beams with a higher building material strength, create a matrix of beams or space them out randomly a required, intersect them with the wall and place them in a hidden layer.
Or you could create a single complex profile beam with many fills in the pattern you want and use that, again placing in a hidden layer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-10-14 05:08 AM
Thanks for your suggestions.
I have modelled it as attached. But now I have a question of how to align the brick pattern to the start corner, say bottom left corner. I can't find any hotspot/placeholder like in the fill, to drag to the corner.
Please help
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-10-14 05:23 AM
You can snap to the bottom corner of the wall or to the bottom corner of an opening.
That assumes your surface material has been set up with the texture and hatching to start from one of those points.
But it is clear from your image that the openings do not match the brick hatching anyway, and you can not stretch the hatching.
You will need to create a new surface or adjust the openings so they match the hatching.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-10-14 05:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-10-17 06:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-30 10:44 AM
The Dropbox file has been deleted. Is it possible to share this file again?
Thank you
