CURSOR notification
mukster
having a slight problem. When you hover your cursor over and object, a  little tag usually shows up that tells you what it is. Mine is not showing up Probably just a button that's pushed. Any ideas?
In your Work Environment, you want to 'enable element info tag'.
Kind of works. It works in the work field (main screen), but not in the Design bar
What is the Design Bar?
