CUSTOM BLOCKWORK FILL
I am trying to create a new fill that shows 190x390mm concrete blocks with 10mm grouting. I see there is a fill for a 200x400mm block but I need the double lines to show the grouting between the blocks. I have looked in Options>Element Attributes>Fill Types and tried to create a new fill. But I'm not sure how you would go about creating the double lines to reflect the grouting etc.
4 REPLIES 4
Place a Hotspot 10mm above and to the right of your 390x190 lines. Select lines AND hotspot, and paste into your symbol fill
rocorona
s2art wrote:
AND hotspot,
or play with the "Strokes" parameters (x1, Y2)
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Hi again. Thanks for the replies. I've found it easy enough to create a fill for a stack bond with the concrete blocks (including showing the grouting), but I need the fill to show a stretcher bond (overlapping half blocks). Ive tried to draw this with hotspots etc but I cant quite figure it out. Any ideas? Regards
Never mind, I figured it out with jus using the strokes parameters. Easy enough.
