ā2008-03-21
03:18 PM
ā2023-05-23
05:02 PM
Rubia Torres
ā2008-03-22 04:42 AM
Jesikuh123 wrote:False. But, as far as I can tell, don't use the AC window's trim.... Define the window's trim in WallBuilder Settings> Openings> Trim. See attached.
True or False: In order for the Accessories tool's siding to frame a curved window correctly, instead of leaving a rectangle around it, you must use a window from Cadimage Door and Window Builder Add-On.
Jesikuh123 wrote:I only use the cladding in 3D/elevation views. You can choose to have the C.I. siding show in plan, elevation, section or 3D via layer management. It's Personal preference. Use none, one or the other.
I am putting siding on a wall.
It seems to work by adding an OBJECT to the exterior or the wall.
When you guys use this, do you not include the siding in your profile or composite since the accessories tool is going to include it?
Jesikuh123 wrote:It should be loaded into the AC Help Menu. "Cadimage Accessories"
OH- and i dont see a read me file or help menue. Maybe I deleted it?
Jesikuh123 wrote:No, it will: Wallbuilder settings> General> Wall Top Shape> Follow Wall
Does this tool not follow slanted walls?
ā2008-03-22 03:06 PM
ā2008-03-22 05:12 PM
Jesikuh123 wrote:Cadimage is located in New Zealand,
Are you serious about the Land of Long White cloud?
Hard to sense sarcasm in in a forum.
If you are serious- Are they? What is that about?
ā2008-03-22 06:57 PM
ā2008-03-24 04:18 PM
