Learn more
Volt
Beginner
Calculating split poligons
Hi all,
Im moddeling an existing building in ArchiCAD as a research project. I made some complex profiles, maybe 10 different ones. I used them to recreate the detailed facade of the building. in 3D everything is buttery smooth. but when i go into an elevation and add for example a window to my wall i get a message that ArchiCAD is calculating split poligons. this takes like 30 seconds to happen. the CPU load or GPU load on my system is not that high (around 10%).
What can i do to make it faster? i have never had this before even with way bigger projects that had way more details, SEO's and windows/curtainwalls.
Operating system used: Windows 27.0.0
0 Replies 0
