2022-10-23 12:30 AM
Please how can I record first and upper floors as I do record the ground floor with 'create fly-through'?. My problem is that I can only record the ground floor. I mean if I select first or upper floors and set the cameras in first floor, it always record the ground floor.
Solved! Go to Solution.
2022-10-23 08:09 AM - edited 2022-10-23 08:10 AM
Eman,
you will need to set the camera height to eye height plus the elevation of the desired floor level above project zero
eg for my project. - 1550mm (typical eye height) + 4500mm = 6050 first floor
- 1550mm + 8700mm = 10250 second floor
Eman,
2022-10-23 01:41 PM
Hi Scott, thanks very much.
