Camera settings - bug?
Hi!
A couple of days ago I encountered a problem with the camera settings. If I place several cameras in my model to make a "fly-through", I cant edit framerate etc. When I click on the button "set" (se attached file), ArchiCAD closes without warning. This happens EVERY time i hit set. I occurs at the office (commercial license) and at the university (EDU) where I teach. All students got the same problem on 20 or so different machines. Have anybody experienced this problem? Ideas?
thx
/Jan-Mikael
2 Replies 2
Hi Jan-Mikael,
Most definitely I would suggest check your Quicktime installation and also your graphics card drivers....
I have seen this problem many times it is solved through one of these updates...
Thanks
Alan
ci-JoshOs
I've had the same problem as this. Using WinXP 64 and the latest version of Quicktime, it always does this for me. I went back to Quicktime 7.1 and all is now fine. you can download it from www.oldversion.com
Josh Osborne - Central Innovation
Mac Mini
