Camera settings - bug?
Hi!
A couple of days ago I encountered a problem with the camera settings. If I place several cameras in my model to make a "fly-through", I cant edit framerate etc. When I click on the button "set" (se attached file), ArchiCAD closes without warning. This happens EVERY time i hit set. I occurs at the office (commercial license) and at the university (EDU) where I teach. All students got the same problem on 20 or so different machines. Have anybody experienced this problem? Ideas?
thx
/Jan-Mikael
Hi Jan-Mikael,
Most definitely I would suggest check your Quicktime installation and also your graphics card drivers....
I have seen this problem many times it is solved through one of these updates...
Thanks
Alan
henrypootel
I've had the same problem as this. Using WinXP 64 and the latest version of Quicktime, it always does this for me. I went back to Quicktime 7.1 and all is now fine. you can download it from www.oldversion.com
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
