Can I add a screen door?
I'm wondering if there's an option to add a screen door to an exterior door? I've been looking and can't find one, I'm having to draw them in manually using lines & circles, a little annoying...
While I'm on the door topic, what is the difference between a standard exterior door and a standard interior door? They seem to have all the same options, and I can make an interior door look just like an exterior one.
Also while I'm rambling... It's a little annoying that they don't have an exterior french door. I just use an interior "D2 12" door if I need to make a french door. Should they just combine the exterior/interior door folders or what??
2 REPLIES 2
Erika Epstein
On some projects I put a second door in the same space as the main one, no casing or frame, and open out. It works.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erich
Steve,
I have a door object that I wrote that includes a screen door in 2D and vastly increased levels of control over the standard doors. PM me if you are interested and I will send it to you to try.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
