‎2007-11-07
07:53 AM
‎2023-05-23
05:04 PM
Rubia Torres
‎2007-11-07 08:34 AM
‎2007-11-07 11:58 AM
‎2007-11-07 03:39 PM
‎2007-11-07 05:22 PM
‎2007-11-07 07:42 PM
Jesikuh123 wrote:No you cannot use columns to SEO walls, but you can use columns and SEOs on other model solids.
Oh, while we're on the subject here:
Can you NOT use column as SEOs?
Seems to me I can not.
‎2007-11-07 07:44 PM
How do you do that?Execute hole of using Solid element Operations, possible in two ways.
‎2007-11-07 08:08 PM
‎2007-11-07 08:18 PM
Erika wrote:I am not sure that I am trying to acheive anything really, just understanding.
I'm not sure what you are trying to achieve, but with columns you do have choices in its settings box for how the column will relate to a wall. Also Layer priorities.
HTH
‎2007-11-07 08:31 PM
Jesikuh123 wrote:Walls, beams and columns have special, automatic, SEO-type relationships so doing actual SEOs on them doesn't make much sense. Erika is right (as far as I can tell) that SEOs don't do anything with walls and columns. Beams and columns can use SEOs with each other but I'm not sure why this would be useful.
