Can't add lines to mesh
I am following the Graphisoft tutorials to learn Archicad v20. I have the solo version.
I am trying to form the terrain landscape of the site, by producing a mesh from the tutorial survey dwg drawing. I create a rectangular mesh and then try to add the contour lines form the survey, by using trace reference. When I use 'space-click' by holding the space bar down (magic wand) it only selects part of the survey contour lines and not the whole line. No matter what I do, I cannot add the hole line to the mesh.
Does anyone know how to solve this?
Tanks,
T23
3 Replies 3
Is the line that you are magic wanding continuous?
Sounds to me like there is a break in it.
The magic wand will only add the continuous portion of the line.
Can you post a screen shot of the result?
Hi Barry,
I have just replied to this in the other thread too. Seems like I was not clicking the line quickly enough, which does select the whole line. If I hover then click, it only selects a part of it!
Thanks for your help,
T23
That's interesting.
Maybe it needs to wait for the blue guide lines to activate.
