Cannot offset polygonal wall
Hello. I just noticed that i dont get the offset edge tool on a polygonal wall unless it suspend the group and i select all the segments again. Is this an issue or is something i don`t know? It would be easier to be able to offset just right away.
You shouldn't need to select the walls again.
Just select the group (with grouping enabled) and then suspend the groups.
The elements will remain selected and can now be offset with the pet palette option.
Your other option is to use the offset tool and magic wand the group - no need to suspend then.
The suspend group is indeed working without the need to re-select. Thanks!
