Cannot open AC9 Layout with AC10
I'm using AC10 on a new intel PowerMac. When I try to open my old AC9 plotmaker layout I get the message that AC10 cannot open this file. How can I get my layouts upgraded to AC10?
Also I cannot see how to save my AC10 file down to AC9. I could create the drawing either way.
8 Replies 8
Laura Yanoviak
Can't help you with the first one, but you can save down to AC9 by "Save As..." and select Save as type "Archicad 9 Project". Unless you are trying to convert to PlotMaker, which I do not think is possible???
Talked to graphisoft about both issues. It seems that the first issue (Not being able to open an AC9 layout book) is a bug with the Intel version of AC10. The second issue (not being able to save down to AC9) is a designed response to AC9 not being supported on Intel Macs. Beware you will not be able to save down if you go exclusively with Intel machines.
This seems a bit over-cautious since AC9 seems to run just fine in Rosetta (about as well as it does in Windows on the same machine).
There still is not an update for this issue. As we continue to migrate to intel machines this will become a major problem. Any word from graphisoft for correcting this major bug?
Andy Thomson
Mentor
Is this a single sheet or the whole book? I am sure you have been all over this, but have other users tried to open your file? I haven't encountered this issue yet. My LBK files show as 'unix executables' but they have opened fine on my mactel iMac.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
It's both, the AC9 layout book is greyed out on the macintel. I've spoken with graphisoft and it is a bug with AC9 layouts that contain PMK's.
Andy Thomson
Mentor
Weird, mine just look like this (loaded with PMK's - note, this one is 380MB - but they open alright)
Keep us up to date about when they fix the bug, or what the cause is/was....
Director
kevin b
We are having the same issue, none of our new intel machines can open plotmaker 9 files. This is a major major bug.
Any word on a fix???
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
