on 2026-04-30 02:32 PM
What if one single tool could carve wall niches, punch a clean multistory shaft, and transform a flat facade into a historical style elevation? The Opening Tool in Archicad 29 does all three, and this article walks you through each workflow.
The Opening Tool is not just for punching holes through walls. With a limited depth, it cuts partway into a wall to create a clean, recessed niche.
Select the Opening Tool and open its Settings.
Set the depth to Limited, from 0 to 400 mm, so the opening cuts into a 500 mm wall without going all the way through.
Keep the Orientation set to Aligned and switch the Shape to Polygon for a freely drawn, custom outline.
Modeling an elevator shaft floor by floor is time-consuming. With the Opening Tool, you can define the void once and extend it through every story in a single step.
Activate the Opening Tool and switch the orientation to Vertical with a Rectangular shape.
Match the inside dimensions of the shaft walls and place a single opening at the elevator core location.
Jump to 3D, select the opening, and click the Home Story icon to add every story the shaft passes through, from the basement all the way up to the roof.
A polygon opening with infinite depth cuts through the full thickness of a wall, making it ideal for shaping facade profiles directly in Elevation view.
In Elevation, select the Opening Tool and open its Settings.
Set the depth to Infinite so the cut passes through the selected wall completely.
Switch the Geometry to Polygon and ignore the anchor point, since you will be drawing a fully custom cut.
| Use case | View |
Shape and Orientation | |
| Wall niche | Section | Limited (e.g. 0–400 mm) | Polygon + Aligned | |
| Multi-story shaft | 3D / Floor Plan | Through all stories | Rectangle + Vertical | |
| Historical facade | Elevation | Infinite | Polygon + Custom |
To deepen your skills and explore more advanced workflows, check out the Learn Archicad! program.
