Bob Moore
Casing on DBL hung window
As you can see in the attachment the casing around the double hung window in about 3" wider than the opening, which leave the exterior siding showing. I've tried about every type of adjustment in the window default setting menu. Any suggestions as to why Graphisoft thinks casings should not fit the window?
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
1 Reply 1
Bob Moore
Whoops! It had to deal with using a special profile. I've got it fixed.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
