2013-02-0711:22 PM - last edited on 2023-05-2505:59 PM by Rubia Torres
Casing on DBL hung window
2013-02-0711:22 PM
As you can see in the attachment the casing around the double hung window in about 3" wider than the opening, which leave the exterior siding showing. I've tried about every type of adjustment in the window default setting menu. Any suggestions as to why Graphisoft thinks casings should not fit the window?
