Centering Using Distribute -1
This is probably very basic to veteran CAD drafting people, but I just recently noticed it...
You can use the Distribute -1 action of the multiply command to center an element. (I think I can describe this without a picture.) To center an element between A & B:
1. Place the element at A.
2. Multiply. One copy, Distribute -1.
3. Click at A, then B.
4. Delete. This gets rid of the element at A, leaving the element halfway to B.
It helps in a lot of situations where the special snap points aren't cooperating.
It's especially useful to center something in a box: Place at one corner, multiply to the opposite corner. Great for downlights in coffers on the ceiling plan.
Begging your pardon if this really obvious,
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Djordje
Special snap point does this even better ... but the tip is good especially for the cases when you need to lock a coordinate, and the Special snap point still gets confused (this was reported in 7 ...)
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I believe this has been fixed.
