Chamfer railing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-11-27 05:39 PM
Hello everyone.
I have a railing for which I would like to make a corner chamfer (point A).
I was expecting a similar behavior to all archicad tools (wall, polyline, curtain wall...), but the expected result (line B in red) did not appear. Instead, result C appeared: the chamfer acted "after" point A rather than on point A.
Is this a bug? Or inconsistent behavior?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-10 07:21 PM - edited 2023-12-10 07:26 PM
That can be corrected by adjusting the reference nodes of the railing.
see attached video - https://app.screencast.com/oitajJ51eKreM The link will only work for a few days. Then I delete them because my library for that is full and I don't want to pay for more storage 🙂 You can set the distance of the railing reference line to be offset any distance from the railing (if that helps).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-11 11:46 AM
Thank you for the answer Steve, but it seems to be a manual solution when railings should behave like any other tool.
It meens that if i want a "clean" solution, i should draw first a polyline and apply a corner chamfer ? or draw circle at each connection as reference?
It is not optimal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-11 07:44 PM - edited 2023-12-11 09:19 PM
I agree that this is not the expected or proper result when using the Fillet/Chamfer tool. However, are you certain that there is no way to configure the settings of the railing for the desired result? Even if there is, drawing a circle and stretching the nodes to get the desired bend could be the more efficient way to get what you want anyway. ?
" should behave like any other tool...." It does - it almost does what you need it to do 🙂
