Change/Edit Story numbers
Is it possible to change the story numbers?
3 Replies 3
Erwin Edel
You can manually rename them all in your cloned / saved views, but you can't change them in the project map.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks. What appears in the IFC file? Cloned View or Project map settings?
Erwin Edel
My guess would be project map, as ArchiCAD will show you things linked to the project map story number too.
www.leloup.nl
