Change curved wall to be a straight wall
Can I change a curved wall to be a straight wall easily without erasing curved wall and putting in straight wall?
Thanks,
Michele
V9
3 Replies 3
Yes. If you select the curved wall, grab it and select the "insert new node" pet pallette button, instead of adding a node it will actually straighten the curve. Don't ask why.
__archiben
yes - click somewhere along the length of the curve and add a new node using the pet palette. the wall snaps back straight.
HTH
~/archiben
b e n _ f r o s t
Sounds better when ~Ben says it.
