Change curved wall to be a straight wall
Can I change a curved wall to be a straight wall easily without erasing curved wall and putting in straight wall?
Thanks,
Michele
V9
Yes. If you select the curved wall, grab it and select the "insert new node" pet pallette button, instead of adding a node it will actually straighten the curve. Don't ask why.
__archiben
yes - click somewhere along the length of the curve and add a new node using the pet palette. the wall snaps back straight.
HTH
~/archiben
b e n f r o s t
Sounds better when ~Ben says it.
