Changing Window & Door Symbols using the
Is there any way that you can copy the window and door symbol attributes from one window or door to another with out changing all of the other properties of the object to be changed. It takes a lot of time if you have to change each one individually and you have to do 50 of them.
3 REPLIES 3
Stephen Dolbee
Alt-click the door to be copied. Then, Control-Alt-click the doors to be changed.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Using the Eye dropper and the syringe. I have a mac g4 laptop running os-x so I think the keys are a little different. Mine are apple click and apple option click. Copies all of the properties. That is if you dropper a door symbol on a single door and syringe a double door the symbol properties will change, which is good, but the double door becomes a single, which is not good. I was hoping there was a way to change just the marker properties without changing the door itself.
Djordje
If you know which properties are mutual, use Find&Select to select the doors/windows in question, and then change the ID/marker text at one go.
Also, try applying the syringe to the preview in the Library window (lower left panel by default); undocumented feature that many spoke about, Karl first AFAIR.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
