Changing material colors
I did a search of the forum and I've looked for it in the AC manuals but cannot find out how to do this:
How do I change the color of an existing material? For instance, how would I make the 6" horizontal siding that comes with AC a color other than white?
Thanks,
Rick
3 Replies 3
Eduardo Rolon
You have to create a new material under Options->Element Attributes -> Materias, select the one you want to use DUPLICATE it and edit.
Please check Help -> Archicad Help -> Index -> M -> Materials
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Dwight
Huy yuy yuy! Such a small question for such a big answer!!!
Change color in WHAT viewing method?
If you want to tint a material in an anlytical view, that is a different problem than for rendering.
If you refer to the 6" horizontal siding: 06 | W Siding - 06" H
whose horizontal lines are created by an image "Lines H Gradient Alpha"
this material is controlled:
For Internal Engine rendering:
-- by adjusting the Surface Color setting in the "Exposure to Light" dialog.
For the LightWorks engine:
-- specify "Match Internal Engine" to have the color change.
It is good policy to never edit a material but make a new one as ej suggests.
Many materials render according to an image mapped on their surface. To change the appearance of these materials requires editing this image map in a photo editor. Lightworks has a built-in way to tint image maps.
OpenGL needs this method to replicate color and will not respond to the internal engine color change method.
For color in analytical section views, in the Model Display dialog box specify:
Uncut Elements>Fill Uncut surfaces with: Own material color.
Dwight Atkinson
Thanks for the help. I'm trying to create some lattice. I started out with the chain link fencing material and am trying to get it from that. I'll figure it out eventually.
