Changing multiple wall height in 3D window.
I just found out that when I select more than one wall in 3D window I lcan't stretch the height of those walls. Is that the bug, or loose of functionality. If the second one, this schould be corrected in next hotfix (otherwise just fixed).
10 REPLIES 10
i try all work
1. work if use coner wall
2. not work if use intersect wall
3 is not work if i need stratch 2 parallel wall
