Changing the Datum Hight
I have a completed job that was originally done using a datum of 10.00, However the planner has requested that we work to A.D.H (Sea Level) so my drawings need to show the new levels. If I raise the model by adjusting the stories elevation, I would then need to go & adjust all the sections (15 in total) and the the work book layouts.
Is there a way of setting the levels without elevating the model?
4 REPLIES 4
Rod Jurich
.............. yes, see attached.
Mine shows my default AHD -1000.
Set to what the project requires and reference your dimensions accordingly.
Rod Jurich
Thanks Rod, too easy. I really should sit down & read the manual again.
Djordje
You should still go through the S/E and check the level dimensioning, as well as the plan level dimensions, and check what do they refer to.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje
You right, I sill had to change Dims to Reference Levels, but a lot easier than what I was going to do.
