Church Steeples
Hi all, how can I draw this church steeple, without using GDL, of course.
I trying Mesh to Roof, but I can't define the curves, is too complicated.
I have Archicad 13.
Sorry for my bad english.
Thanks in advance.
14 Replies 14
Dwight
Use Complex Profile.
Eric's article yet again
Dwight Atkinson
Steve Jepson
Ce is nume de la biserică?
Unde este biserică?
Dwight
Once you've made the profile, use the magic wand with 'linear segments' to place eight straight custom profile segments within the circle diameter.
Dwight Atkinson
Great illustration/example, Dwight!
...and to Emyl001 - when you read about defining Custom Profiles, you will see that you can define different materials for different edges / surfaces using the pet palette...
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
For-mentioned edge control.
Click on any edge between two nodes, then while holding down the mouse,
this little icon is your friend.
lec
Thanks for advice I hope to succeed.
@ Steve Jepson - I don't know what is the name of the church and where is it.
It's just a picture.
Steve Jepson
ok. I am looking for it on the web.
Dwight
Biserică Ceapa Bulbucaţi ?
Dwight Atkinson
