TJ1
Ci tools Transformer - Mirror Project issue
I'm experiencing an issue when using the CI tools transformer function to mirror a project. When the job gets mirrored all the Title markers will randomly change its settings. eg. will add a north point & text size will change. Has any one else experienced this or know of a fix?
1 Solution
TJ1
Got the response from Central Innovation, they claim its just a bug in ArchiCAD25. They did not experience the bug in ArchiCAD26 or later so will just need to upgrade versions
Go to post
3 Replies 3
Don't forget to contact Central Innovation for support while you wait for an answer here.
And if you do get an answer from them, please post it here as well.
TJ1
Thanks for getting back with an answer.
You can always install 28 and run in demo mode to test before you buy.
Unless you need a licensed copy of 28 to be able to get the 28 CI Tools?
