ā2025-06-26
03:09 AM
ā2025-06-27
08:18 PM
I'm experiencing an issue when using the CI tools transformer function to mirror a project. When the job gets mirrored all the Title markers will randomly change its settings. eg. will add a north point & text size will change. Has any one else experienced this or know of a fix?
Solved! Go to Solution.
ā2025-08-05 03:02 AM
Got the response from Central Innovation, they claim its just a bug in ArchiCAD25. They did not experience the bug in ArchiCAD26 or later so will just need to upgrade versions
ā2025-06-26 03:14 AM
Don't forget to contact Central Innovation for support while you wait for an answer here.
And if you do get an answer from them, please post it here as well.
ā2025-08-05 03:06 AM
Thanks for getting back with an answer.
You can always install 28 and run in demo mode to test before you buy.
Unless you need a licensed copy of 28 to be able to get the 28 CI Tools?
