Circle with Fill
Hello,
Is there a reasonable way of explaining why a circle cannot have a DIRECT fill in Archicad? Thanks.
23 Replies 23
Dontknow
When you draw a fill as a circle its possible.
Use your pallet to draw a cirle with the fill tool.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thank you very much.
Am I missing something with this, I currently draw a circle with the circle tool then magic wand the fill & delete the circle!
So whats the trick to cut out the first step?
If you use the Polygon geometry method the Pet Palette pops up with the various arc creation methods. I find it easier just drawing a circle and using the magic wand.
Amazing this was right under my nose & didn't see it!
Dontknow
Made a short video of it.
Here is how it goes:
Draw a fill cirlce
ArchiCAD 25.
That is a useful tip, however, there are times when you need to draw a circle from a known centre point. The fill method requires a start point on the circumference. I have always used the circle and magic wand method.
I wish the super talented programmers at Graphisoft could just give us a simple "one-step" circular fill tool. How hard could that be?
If you know the center of the circle and the radius (let's say 1000 mm), then move your cursor to the center point, type "X1000+" to input the point on the circumference, then use the Pet Palette method shown in the video to create the Circle shaped fill.
If only a fill (and other elements) could magic wand to a guide circle.
"M" (measure), click centre, type in distance (radius) and mark location to get the guide circle.
Now magic wand the fill on the guide - no need to delete a temporary circle.
Shame it doesn't work.
