Circular Slanted Flat Roof???
Scratching my head on this one. I'm looking to achieve a slanted flat roof that will contain a round skylight. I can get everything but the roof itself..I am obviously missing something because I cant figure it out for the life of me. There is probably a simple solution that I'm over looking.
undefined
Eduardo Rolon
Any reason why you can not use the Roof Tool?
  • - Draw the walls
    - Select single plane roof
    - Draw pivot line
    - Magic Wand the Roof perimeter to the walls
    - use "Connect to Roof to trim the walls
Eduardo RolĂłn AIA NCARB
AC28 US/INT -> AC08
another Moderator
Wow! I wasn't familiar with the roof tool enough to know you could use the wand. I used it to cut the walls then attempted a pitched morph and it wouldn't work. I'm an idiot haha I knew it would be something simple. Thanks a lot!
Eduardo Rolon
Not an idiot, Newbie more likely and all have been there at one point or another.
AC28 US/INT -> AC08
another Moderator
