Cirlce where arrow snap points should be. Help!
I'm seeing a circle where an arrow snap point should be. i cant seem to get functions to work when this happens. can anyone help me
4 Replies 4
This has nothing to do with snap points - but to what you chose for your arrowhead style. See attached.
please see attachment file for clear picture of the problem. above in picture you can see some circles.. and below you will see the training video where you will see all points with arrows. when i try to complete function as in training video this is what i see.. and function cant be completed.... Thank you
Your 2.1 and 2.2 on top have circles instead of arrow heads as shown in the training video at the botom. The screenshot I gave you shows where that is adjusted.
The other circles seem to indicate that you have the label tool selected with something other than 'text' as the label setting.
It is possible the training videos just didn't give you the correct steps to match what they are doing...hard to say without watching them.
thank you very much.... apparently training sample solo project has some presetting that are not align with training video, seem to be only a visual affect and doesn't prevent you from completing steps of the training.... functions did work after all. I selected the label, turn on the label tool "document/document tool/label" click settings dialog and made the adjustments there.
