Clean Wall Intersections
I'm at a loss...
I have been working on this project for months w/o problems, but this morning when I joined the Teamwork project some of my walls aren't intersecting cleanly (when they had before).
This is happening to only some walls.. there seems to be no rhyme or reason as to which ones. It does not appear to effecting one certain wall type or all walls on a certain layer.
Also, I have 'Clean Wall & Beam Intersections' turned on.
Can anyone help.
3 REPLIES 3
Erika Epstein
Have you checked that the different walls have the same layer priority number in the layer settings box?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
You should also check the Wall heights and that they may intersect with another Wall on the Story above/below.
I forgot to mention that they also had the same layer priority. Also, they do not intersect any walls above (they actually run up all 3 stories).
I did go to a backup from the BIM Server and found that all of the walls were displaying properly. So I have fixed the problem on my end, but still don't know why it happened or what caused it.
Thanks Erica and Laszlo.
