It is there in the menu in the Standard work environment but not with the keyboard shortcut.
But the command has changed.
Used to be "Close".
Now there are two new commands "Close Window" and "Close Project".
So if you are using your old work environment then you will find the old "Close" command is missing.
You will need to amend your work environment to add it back in.
