‎2006-07-05
08:56 PM
‎2023-05-23
05:15 PM
Rubia Torres
‎2006-07-05 09:08 PM
‎2006-07-05 09:15 PM
‎2006-07-06 12:36 AM
‎2006-07-06 01:00 AM
‎2006-07-06 03:30 PM
‎2006-07-16 05:27 AM
Demetious wrote:that's the crux of the RGB '-2' pen. it's an archicad-only pen for use in exactly the circumstances you describe . . . once you have your elevations generated, Select All... then Copy and Paste it back to another area of the elevation window (or convert the sect/elev window to a drawing if you want to). now take a look at the exploded fills archicad has generated . . . because it's possible for the the adjusted colour not to match anything in the penset, archicad matches the fill background colour to an RGB value. unfortunately we can't (yet) edit it or change those RGB values ourselves manually.
I was instead talking about if you use a basic color/material and then open an elevation with shadows on, AC changes the original surface color to adjust for lighting.
I'm not sure what you are referring to, maybe the spotlight tool on a Mac to find the colormatch program easier? I don't know of any magnifying glass in AC10. Please explain further.when you bring up the colour picker palette - click the magnifying glass icon and you can match to the colour of any pixel currently on screen . . . see attached image.
